2004 titain no start u1000 code please help
Clang114
Car: 2004 Nissan Titian
2004 titain fixed front brake solenoid valve put back in truck..... no start just clicking under glove box.... also u1000 and u1001 code.... put a brand new valve body and tcm in same thing.... took a wire ran from battery to idpm box to fuel pump fuse and jumped the starter relay.... cranks up and runs but trans... stuck in limp mode.... anybody have any clue.... I no the dealer is going to bleed me dry
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Check the A/T fuse in the IPDM, you may have blown it during the repair. If the fuse is good then it has to be a wiring problem.
Clang114
Checked it and it's good..... I have checked everywhere for wire problem can't find one..... but when I took the valve body out one wire did break but I fixed it....
