biyanpian »
https://forums.nicoclub.com/biyanpian-u280275.html
Tue Jan 23, 2018 12:11 pm
I recently did this. The engine is the same. You'll need to swap over (from the supercharged engine) the supercharger, throttlebody -> supercharger plenum, supercharger -> intake manifold plenum, intake manifold, injectors, crankshaft pulley (harmonic balancer), idler pulley bracket with pulleys (the one sharing the belt with the supercharger, crankshaft pulley, and AC compressor), and AC compressor pulley (or just the whole AC compressor). You'll also need to use the throttle cable and ECU/ECM from the supercharged car, obviously. Don't forget to use high octane gas. I suspect failures in these SC engines are due to owners using low octane.
