DsR_240_ToUgE »
https://forums.nicoclub.com/dsr-240-touge-u49797.html
Tue Oct 31, 2006 9:50 am
ive ran into the same problems and i think thats its def. the fuel pump....the best way that i prevent that from happenning is by priming the fuel pump b4 actually starting the car, meaning i put the car in the on position for like 2-3 seconds b4 i actually crank the engine... you will hear the fuel pump prime itself and as soon as you hear it stop crank and it starts 100% of the time.... the only time the no start issue happens is when you rush the start up, which unfortunately cannot always start the spec v's, its wierd i dunno... nissan must've put a real bad fuel pump in these b15's...lol... but im planning on putiing a walbro 255lph fuel pump in within the next couple of months so ill fill you in if the no start problems dissappear.... the temporary fix i suggested would hafta do for now... lemme know if it works
