DizzyKitty »
https://forums.nicoclub.com/dizzykitty-u120763.html
Tue Aug 13, 2013 6:53 pm
Hello and thank you for taking the time to read this post. My aunt has a 2004 nissan sentra that is currently stuck at a Goodwill Parking lot. When you go to start the car, the accessories turn on, but the car will not crank when you turn the key. Instead, there is clicking coming from the relay box (black one, left side second one down. Think it is the ignition relay?) also, after you turn the key to start the car, all of the accessories turn off and wont come back on until you fiddle with the key a bit.
From what i understand, before i got around to looking at the car, she had her car jumped successfully up till she put the car into reverse to drive away. This happened a few times until it stopped responding to jumps entirely. The strange thing is, as it stands now, the battery is fine (seems fine as it powers all of the accessories, also i took it to autozone to test).
so, any opinions as to what it could be? Any advice as to how to get the car started so we can move it out the parking lot? Tomorrow morning i'm going to buy another relay, but i'm not entirely convinced that is the problem. I also suspected the neutral safety switch, but would that cause all of the symptoms that the car is having now? The last thing I suspect, is that there is a broken wire somewhere, but i am hoping that isn't the case.
Again, thanks for your opinion on the matter.
