Try replacing the Thermostat. they are typically cheap. it may be causing your issues.Whoopee wrote:I have a 2004 Sentra 1.8L automatic transmission with 150000 kms.
The other day the car failed to start. Apparently this model has had some starter issues?
Anyway, engine was flooded. Sparkplugs were changed and car started fine.
Problem now is the heat is not working and the engine coolant gauge is acting up even though it's never happened before. Levels are okay. Oddly enough it happens when idle at a light or when turning right??
Never had any issues with the car and have had regular maintenance on it.
Had a 1989 Nissan Stanza that lasted until 2003 with 250000 kms, without any problems.
Father had a 1979 Datsun 510 without any problems.
for your sake i hope not. I hope not.Whoopee wrote:Thanks. Getting it checked out. Hope it's not a blown gasket.
