2004 Quest - Problems?
bad1550
I have the SL and had the Door Rattle adjusted a couple of weeks ago.(Left side slider) It seems to be better except now but I have another rattle coming from the front area of the car (cannot pin point it yet).
Also I mentioned about my radio cutting out twice and they found no problem but today it happened a third time (Resolved when you restart the car.)
Still would like to get these issues resolved!
NISTECH
have they put an audio unit in your van yet??
I dont have any knowledge of a rattle from the engine area as of yet.
FYI I found out that nissan has an entire engineering team dedicated to the sliding doors on the quest if thats any comfort to new quest owners. And I dont mean these guys are dedicated to the Quest, this crew is only dedicated to the slider doors on the Quest. There is another crew dedicated to the vehicle as a whole.
bad1550
No, They have not put a new audio player in the van. When I brought the car in, they found nothing wrong with it?
Thanks,
Bob
NISTECH
sounds about right we are instructed by nissan warrenty division if we dont verify it we are to do nothing.(after reviewing asist for any related TSB's)
JONBOYRACING
at my dealer we found the best way to take care of the sliding door noise..... (only after the sliding door adjustment).. if still makes noise we weld on the B-post at the lower part all the way around where post meets the floor pan.. has fixed everyone.. we have performed about 7-10 times...
NISTECH
Is It approved by warrenty to do it ?and if so could you detail the work performed? This way I can attempt to get vcan approval to do it at our dealer. We have quite a few concerns on this and we keep telling them engineering is working on a repair. But if this is an approved repair we can send them to the body shop for repair. We dont have a body shop or welder on site.
JONBOYRACING
yeah, we do get it approved by warranty.. ill have to get the op. code that we use..but do know that it is straight time. i normally clock about 1.0 for service. the body shop around 2-3. i will have to take some pics of where we weld but it is near where the seat belt mounts at the bottom
NISTECH
cool I would appreciate it. I knew it was straight time but its always been tighten this, adjust this and never a body seam repair.
JONBOYRACING
it is a repair that we came up with... we just kept having the 04's coming back about week later with same noise....and someone tryed this after removing all the trim and finding that it was coming from the B-post and floor pan....seam
KaDrifter
A Nissan Engineer came to my dealership to work on a 04 Quest rattles with me there are new dovetails for the doors and the realign per the TSB
bad1550
I continue to have problems regarding the radio not working. It has happenned twice this week and about 6 times since my purchase 7 weeks ago!
I have to shut off car and restart to resolve this problem. Is Nissan working on a resolution to this problem. I've read numerous complaints about this problem!
Bob
NISTECH
I am not sure on the radio I havent had to deal with it at all and your case is the first I have heard. Where do you live maybe its climate/temp related?
bad1550
NISTECH wrote:I am not sure on the radio I havent had to deal with it at all and your case is the first I have heard. Where do you live maybe its climate/temp related?
Hi,
I live in NY! See attached link regarding this issue!
Bob
http://townhall-talk.edmunds.c...17899!make=Nissan&model=Quest&ed_makeindex=.ef17899
NISTECH
sounds like nissan has a fix for it so go in and bring it to their attention you have done research and found out about this repair. We at our dealer have yet to see it. I handle all work orders through the shop so i would know if we had one in. If I get a chance tomorrow I will look in asist for both the door rattle TSB and the radio one.
bad1550
Thanks!
Bob
NISTECH
ok official word here on both the radio and the rattle. NO BULLETIN EXISTS FOR THE RATTLE OR THE RADIO PROBLEMS.The only bulletin that does exsit for anything related to the doors is the adjustment TSB mentioned in this thread and that procedure is not to cure a rattle but to correct a door latching problem. Again no bulletin exists for either concern as of the feb 15 asist disk. [We get this disks on the 1 and the 15th of every month. They contain all current bulletins.] I could have done a dial update over the internet but didnt have time. Usually the update doesnt reveal anything new.
JONBOYRACING
i have pics of the door repair that we do http://images.cardomain.com/me...l.jpgh ... .l.jpgthis is after the welding and has been paintedand i have heard that nissan is working on the radio problem
KaDrifter
From what the engineer told me the new dovetails are supposed to fix some of the rattles the current dovetails are all smooth the new dovetails have ridges on them to fit inn the door tighter to prevent the door rattling in the shut position
NISTECH
Thanks for the pictures jon I am going to print them out and take them to work I appriciate it.
Kadrifter. Is it just the lower dove tails that are updated or both the upper and lower ones?
KaDrifter
Upper and lower when he brought them to me he said they haven't been issued yet
