2004 quest abs problems?
A forum for the Nissan Quest... minivan lovers unite!
questboy
Car: 2004Nissan Quest S
hi i just find these club i am try to find the problem that cause abs motor runing wen i turn the ignition key off and turns off wen the ignition is on (or the car its runing)
I was searching in the web and find the unit its bad but i dont take that i think is a sensor or someting ealsedo anyone knows the way or the remedy to fix these problem?
thankyou . :werd:
ricebike
2002 Quest
2005 Altima
may be the wiring... something short to power?
http://www.nicoclub.com/FSM/quest/2004_Quest/lan.pdf
start on LAN-49 to test the circuit :whistle:
questboy
thankyou for you quick respond ***ricebike
i will work on these and i will keep up date on the situation
Return to “Quest Forum”
