mac, couple of things here , the symptoms of your May 27 @10:42am , are talking about AFTER the servicing you've described in the first sentence - including , WOW, "dropping the valve-body" .I didn't think the discussion yet was at all talking going that "Far" into it , I only mentioned a re-torque ( they do get VERY loose many times).
Maybe it was a "slip" in your explanation. Valve bodies , with a couple of sandwitched plates several complex gaskets and ALL THOSE CHECKBALLS - I'm just hoping you didn't do that , if so tell us your strategy/ what it was supposed to accomplish.Any one of a dozen steps in NOT putting it back proper - God wouldn't even know what may go wrong. The only time I've had a valve body out was VERY familiar Turbo 350/400 GM trans I do "shift-kit" installs on ,they have detailed instructions , for an experienced mechanic, to attempt.
IF , let's relax now , say you did a pan/filter/fluid/refill/ back-together , AND your still having much of the same in that your not getting the BASICS - a normal Reverse or a normal 1st (L1) , then probably a transmission expert help is needed. Not evereryone, keep in mind, in the transmission business is ALL THAT,can be a crap-shoot is everyones fear , your not alone
I mean outside of the "Basics" here - and like EdBwoy was talking - to see to it getting proper 'detent' , the mechanical linkage proper , etc, and any other basics that knowledgeable people can recommend - just keep in mind what's key here is trans are not like motors YOU QUICKLY REACH a POINT of no-return , bafflement, how when one realizes just how "in over their head" one can get! Not to mention "Progressive Damage" you may be causing.
