mdmellott wrote: ↑Sun Jul 25, 2021 11:20 pm
You would have an easier go at it if you were to simply mask off the entire roof rack, drape a drop cloth over the entire vehicle, and then paint the roof rack in place. The rack is bolted to the roof from inside the vehicle. See illustration on page BT-42 >>>
https://www.nicoclub.com/service-manual ... 4%2Fbt.pdf
To access the nuts fastening the rook rack in place, the headliner must be removed. To remove the headliner, page BT-36, you practically have to strip the entire interior of your vehicle. The crossbars can be removed and painted separately.
This isn't accurate. There is hardware that is hidden by the headliner, but these mounts do not need to be disturbed (and shouldn't, as the nuts on them will drop onto the headliner). The roof rails are mounted to these mounts, and the rails are entirely accessible from the exterior of the vehicle (no interior work required whatsoever).
Hungry01, your other post said you have a 2004. I presume you have the "SE" rack, which is the one with an upper rail, "PATHFINDER" decals on the upper rails, huge obnoxious oval cross bars, and a wind deflector. If not, the instructions are pretty similar, just less parts (only lower rails and crossbars). Removing either is pretty trivial...once you get the caps off.
Start by removing the caps at the rear of the truck. The caps are awkwardly shaped covers with hidden friction clips inside at the top. Lift the caps straight up, carefully (you may need a pry tool to get started). They can be brittle, and they are getting hard to find. Once removed, it'll expose a pair of torx head screws (T25, IIRC) with rather large heads. For the non-SE rack, there will just be smaller caps that has an exposed torx screw. Remove those caps.
If you have the cross bars still attached, they can only be removed once the plastic "uprights" are removed. The uprights support the upper rail and connect to the roof with two Torx bolts, and a smaller screw that attaches the upper rail to the plastic upright. Remove those 3 screws ONLY, then remove the upright from the vehicle; repeat on other side. The cross bars can be slid to the rear and off the vehicle. To remove the upper rail, you just need to remove another small screw that connects it to the front upright. The upper rails are aluminum extrusions; a wire cup brush cleans them off pretty well.
If that's all you want to remove for painting, then stop there. If you also want to remove the lower rails (those mounted directly to the roof), then you need to remove the front cap (same lift-up fragile plastic as the rear), and then remove the two torx screws (also large heads) holding the wind deflector. Do not remove any other screws.
At this point, you'll have removed 8 torx bolts; 4 per rail (1 long, 3 short), 2 per end. Near the middle of the rail in the channel, there are two more exposed torx heads. If you want to remove the lower rail from the roof, remove those two screws. The rail will feel stuck to the roof, but that's because of the weatherstipping that's been sandwiched forever. Gently pry up the rail.
After everything is removed, you'll see 6 remaining cleats on the roof, each with two torx heads. Don't touch these at all, except if you want to check that they are tight. If you loosen the torx screws on them, the nuts that secure them to the roof will fall onto the headliner. These are the mounts mcdermott was warning about.
When it comes time to reassemble, just reverse steps. Note that the bottom rails have a minor arc to them, so when placed back on the roof, there'll be a little gap. You may need to apply some downward pressure on them in the center when installing the two screws so that they catch into the threaded cleat. The screws are pretty short, but they'll grab.
