Ron Co »
https://forums.nicoclub.com/ron-co-u270349.html
Thu Dec 22, 2016 5:45 am
Going to remove the trans pan, remove and clean the magnet, thoroughly clean the pan, remove and clean the oil screen, then replace it all. Gasket, O-rings & sealant on hand from the dealer. On replacing the pan, the CD-ROM manual I have tells me to use NEW pan bolts because the bolts have sealant pre-applied. Is this necessary? Also my manual has no pan bolt torque value. Does anyone know the correct pan bolt torque?
Will do the usual 'add 4 qts. fresh fluid' as part of this.
Also I will be installing the Filtran inline filter sold by Magnefine, 3/8" nipple size. Magnefine is out of stock for their own 3/8" size filter but tell me the Filtran is excellent. BTW, I measure the metal trans oil line diameter at .385/.395 so the 3/8" nipple should fit perfectly. Any thoughts on this?
Thanks in advance!
