seang »
https://forums.nicoclub.com/seang-u122444.html
Wed Oct 28, 2009 6:36 pm
I wonder if it's just burning off a little bit, but don't know if a half quart every oil change interval would be enough to make blue smoke, hmmm. Is the compression good? Are the valve cover gaskets good? If so, then the valve stem seals might be pushing a little oil, but IDK for sure, these are just ideas. Good thing you replaced the PCV while you were already right there next to it.
