mdmellott »
https://forums.nicoclub.com/mdmellott-u292054.html
Mon May 25, 2020 4:57 pm
You describe what could be a problem with your IACV. If you have a Haynes Repair Manual, there is section in there that describes in detail how to test it. The Nissan field service manual, found on this website also has this information. You will need a multi-meter. There is also an IACV relearn procedure detailed in the manuals that you can perform to be sure your ECU recognizes and regulates the proper operation of the IACV. If your IACV is bad, replace it as soon as possible because faulty ones have been known to wreck the ECU. Figure it out as soon as possible. Good luck.
