Niti QX4 »
https://forums.nicoclub.com/niti-qx4-u273552.html
Sat May 04, 2024 4:16 am
Just adding a "Summary" for the search engines:
2004 Xterra 2.4L, 5 Speed - Crank, No Start (SOLVED)
SYMPTOM: Crank, no start.
SITUATION: 2004 Xterra 2.4L, manual, blew out #3 spark plug boot. Was driving on the highway after filling up the tank. Lost power and shut off. After failed restart attempt, opened the hood and found the #3 spark plug wire missing from the plug hole.
Found the plug wire and boot hanging down on the side of the engine.
Reinstalled the plug wire and still no change in being able to start the engine. It turns over OK, but it seems to have no ignition.
FINDINGS:
1. The plug boot blew out due to a slightly loose spark plug
2. The crank, no start - is caused by a burned out coil. When the plug boot blew off, the spark had no where to go so the coil overheated and failed.
3. Replaced the coil, the cap, and the wires for good measure.
4. Works fine now.
