driftingmy240sx »
https://forums.nicoclub.com/driftingmy240sx-u80467.html
Thu Jan 10, 2008 3:54 pm
the meter ac amp is the module that controls the cluster gauges and the a/c amplifer. if the ecm has no communication check the elec parts fuse. you may not have communication if the scan tool does not operate with "can" systems which require a special converter to scan with a scan tool. with the problems you are having i would recommend taking to the dealer were they will have all the tools needed to diagnose the failure.
