2004 maxima sys too lean-B1
mightybuc
Car: 2004 nissian maxima 3.5 sl
Could someone please help me on finding that would cause my car to run too lean in bank 1? I was traveling from Florida and the car started to sputter and then the check engine light came on. The car has 45000 miles. Thanks for any help on this.
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
You may have a major vacuum leak. To check the intake system for a vacuum leak, attach a vacuum gauge to a full vacuum source. With the motor fully warmed up, the reading at idle should be 18 - 20 InHg. At 3,000 RPM, it should be around 21 InHg.
If readings are under 18 InHg, check the intake manifold nuts to make sure they are tight. Also check the intake plenum bellows at the throttle valve and at the MAF for cracks or loose clamps.
audtatious
This should help you out:
mightybuc
thanks for the help! I'll keep you posted on what I find out.
audtatious
Good deal.
Let us know if you need additional detal. I can post up the other informatin referenced in the image I uploaded if necessary. Probably not needed tho.
