knhardy »
https://forums.nicoclub.com/knhardy-u139910.html
Mon Aug 03, 2009 12:17 pm
I have a 2004 Maxima with 80,000 miles on it. Recently I have noticed an increased ticking/tapping noise. The noise appears the loudest at idle after warm up. It is not noticable at higher RPMS or when it is cold. I thought it could be a stuck lifter so I ran seafoam through the crank case but the noise remained. I'm considering a possible collapsed lifter? However, I listened with a stethoscope and the noise seems the loudest toward the timing chain cover, but I cant tell if it is simply carrying through the metal. Any suggestions would be greatly appreciated.
Thanks,
Kevin
