2004 Max - Timing Chain rattle ?
HeryMax
Car: Nissan Maxima 2004 SL
I have just bought a Maxima 2004 SL with 98k miles. My wife believe that there is something wrong with the engine sound. I believe it is normal, but I would like to know what you guys think. This is my first Maxima, so I can't tell if the engine sound is normal or if there is something wrong with it.
Here is the link.
http://www.youtube.com/watch?v=whGToDowHzs
Thanks guys.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
The VQ's actually pretty notorious for its noisy valvetrain, especially at idle.
It's hard to get a good measure on the volume from the video (which has great audio quality, but nothing else to really judge the noise against). That rattling/clicking at idle is completely normal with the VQ, though. Most Maxima and G35 guys are pretty familiar with that sound. Oftentimes you can even hear it even with the hood closed.
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
06 Infiniti M35 Sports
04 G35 & 99 I30-RIP
I agree with the Minister. It's difficult to say if that noise level is normal or not, based on the video alone. Check if that noise only happens with the air-conditioning ON. If so, problem could be with the clutch assembly or the compressor itself. Another possibility is the Idler Pulley ( impending bearing failure). Check the condition of the belts and alignment with the pulleys. It would be better to use a mechanic's stethoscope (or improvise with a long screwdriver) to isolate the noise problem. You can also apply BG Quick Clean just before your next oil change and see if there is any improvement.
NutriaforBreakfast
Car: Nissan Maxima 1995 VQDE engine
On my 95 I think the timing chain is rattling I think. ONce the car warms up , the noise
goes away. Has to do with the chain tensioner becoming worn. Will replace when
car needs a new water pump. 185K and still holding on. Of course it could be the cam chain
tensioners-its hard to tell.
HeryMax
MinisterofDOOM wrote:The VQ's actually pretty notorious for its noisy valvetrain, especially at idle.
Thanks for your opinion Minister. Here is the record of the engine sound from inside the car. Pretty much all the noise is filtered out, and only the evenly intervaled "dud dud dud dud dud dud ....." sound left.
http://www.youtube.com/watch?v=6dD7VN74 ... 56a05d8b4d
HeryMax
loystock wrote:I agree with the Minister. It's difficult to say if that noise level is normal or not, based on the video alone. Check if that noise only happens with the air-conditioning ON. If so, problem could be with the clutch assembly or the compressor itself. Another possibility is the Idler Pulley ( impending bearing failure). Check the condition of the belts and alignment with the pulleys. It would be better to use a mechanic's stethoscope (or improvise with a long screwdriver) to isolate the noise problem. You can also apply BG Quick Clean just before your next oil change and see if there is any improvement.
I have turned off the A/C to make sure that it is not interfering. I will follow your suggestion before my next oil change.
