I tried to search the forums with about five different keywords but no threads were returned regarding my strange issues.
It started when I tried to adjust my bass control in the CD Changer mode. As soon as I touched the joystick the bass cursor systematically decreased on its own until it moved full left or minimum bass. It would not move to the right. Then I moved the joystick down to adjust the treble and the system continued to move the treble to the left until the minimum position. Same with the balance. Sometimes the display would lock to prevent me from accessing the previous page (back out).
Then magically it was fixed and now the A/C controls (including fan speed and all dash buttons) were frozen without response. The only function available was altering the actual temperature. During both of these gremlins the voice activation would not trigger.
Then this issue cleared and the gremlin moved to the cruise control not responding and the ABS, SLIP and VDC lights illuminating at ignition and remaining on even though no change in performance is evident.
Now yesterday, the issue cleared again and the problem has returned to it's original source affecting the audio page during CD play with the bass and treble controls moving far left on their own.
Each gremlin phase lasted a few weeks before moving on to the next. This appears to be an endless circle of three areas.
Unfortunately, I do not have much confidence in the dealer to inquire.
Any information would be appreciated.
Thank you.
