Double E wrote:For the cruise, if the ICC icon flashed when you power up, I understand that the forward looking lens (black plastic) in the lower pass. side of the bumper is probably needing a good cleaning.
You might already know that If you hold down the cruise control power button, the ICC system turns off and you can use cruise normally until you can clean the lens. It has worked for me even when the ICC system was flashing upon power up.
167 miles to empty with the fuel needle at half is about right for 17.2mpg. But if it also took in 19.4 gallons, while still showing 167 miles to empty, that's not good.
When you say the TPMS shows a flat tire, do you just mean the light on the dash comes on? What pressure does the lowest tire start out at according to the monitor? I only ask because the pressure on cold mornings with mine change as much as 4 lbs. Same thing was happenng to me unitl I added a couple of pounds all around.
I'm curious, what's your average currently at?
No The ICC flash does'nt light up... When i turn on the cruise the green cruise comes up.. When i hit the set button i hear a small beep and the orange cruise light comes up... Thats it... Nothing happens after that.. I turned off the ICC by holding the cruise on/off for 3 seconds. The main cruise is not working so i guess the ICC also wont work..
For the TPMS the light on the dash as well the preasure meter on the navigation screen goes to 0 displaying flat tyre..this is during bright after noon... The other tyres are all proper so i guess the tyre preasure monitor of one of the tyres is busted..
Just 2 weeks back i took it to pepboys to get the break pads changed and then preasured up the tires to 38. All tyres were showing proper when i left then one week later this happens.
