Never, never use Jiffy Lube! Many people have had poor experiences with them. Things like not replacing all the screws in lower engine covers, forgetting to put the drain bolt back on, not using a new copper crush washer that is needed on our engines, not actually changing the filter, not putting in enough oil, putting in too much oil, etc. Too many possible issues for me to trust them!
Since you have a local mechanic that you believe is honest and knowledgeable, use him! Have him do oil changes if you don't want to do your own. This is perfectly fine ... I don't do oil changes either! No lift at home and it is easy enough to get a local guy - with tons more experience than the Jiffy Lube folks - to do it right.
Just buy your own OEM filters and copper crush washers from an Infiniti dealer (or in bulk from
www.everythinginfinti.com), oil from an auto parts store if you want to use your own (I use Mobil 1 Synthetic 0W-40 so buy it myself) and have a local place with a lift do the oil change for me while I watch the work.
Measure oil with the car on level ground, cold engine (overnight in a garage is fine), and fill it up to at least half-way (or a bit higher) between the two marks on the dip-stick - doesn't have to be at the full mark. Of course, checking immediately after adding oil will not give it a chance to settle lower, so just do a good estimate and add enough oil for that - and just check the next morning. On your car, going from the low mark to the high mark is
probably 1 qt - that will allow you to estimate how much you need right away if it is low
And, instead of keeping a quart in the car, I'd just check it every other morning for a while and see if it goes down. Having your local mechanic check your engine would be good too.
Final point: if the oil level on your car is good (halfway between the Low and High marks, the oil light coming on is not related to the quantity of oil per se. Have your guy check the engine for issues.
Z
