Component Description:1. FUEL SYSTEM, OTHER:STORAGE:TANK ASSEMBLY Bulletin Number: EC -08-004 Bulletin Date: AUG 2008 Vehicle: 2004 Infiniti G35 Summary:INFINITI: HARD TO FILL FUEL TANK. THE FUEL TANK IS DIFFICULT TO FILL MORE THAN 1/2. NOTE: FILLING NOZZLE CONTINUES TO CLICK OFF WHEN THE FUEL TANK IS MORE THAN 1/2 FULL. ( NHTSA ITEM NUMBER - 10025971 )
Component Description:2. FUEL SYSTEM, GASOLINE:STORAGE:TANK ASSEMBLY Bulletin Number: EC -08-004 Bulletin Date: AUG 2008 Vehicle: 2004 Infiniti G35 Summary:INFINITI: HARD TO FILL FUEL TANK. THE FUEL TANK IS DIFFICULT TO FILL MORE THAN 1/2. NOTE: FILLING NOZZLE CONTINUES TO CLICK OFF WHEN THE FUEL TANK IS MORE THAN 1/2 FULL. ( NHTSA ITEM NUMBER - 10025971 )
Component Description:3. EQUIPMENT:OTHER:OWNERS/SERVICE/OTHER MANUAL Bulletin Number: ITB 05-051 Bulletin Date: JUL 2008 Vehicle: 2004 Infiniti G35 Summary:AIR FLOW METER SERVICE. ( NHTSA ITEM NUMBER - 10025704 )
Component Description:4. POWER TRAIN:AUTOMATIC TRANSMISSION Bulletin Number: ITB08-022 Bulletin Date: APR 2008 Vehicle: 2004 Infiniti G35 Summary:INFINITI; SPECIAL AUTOMATIC TRANSMISSION FLUID REQUIREMENT. 2004 TO CURRENT INFINIT VEHICLES. ( NHTSA ITEM NUMBER - 10024688 )
Component Description:5. EXTERIOR LIGHTING Bulletin Number: 03031 Bulletin Date: APR 2007 Vehicle: 2004 Infiniti G35 Summary:EXTERIOR LAMP FOGGING. ( NHTSA ITEM NUMBER - 10021509 )
Component Description:6. STEERING:WHEEL AND HANDLE BAR Bulletin Number: 07008 Bulletin Date: FEB 2007 Vehicle: 2004 Infiniti G35 Summary:MANUAL TILT ADJUSTMENT LEVER REPAIR PROCEDURE. ( NHTSA ITEM NUMBER - 10021344 )
Component Description:7. ENGINE AND ENGINE COOLING:ENGINE Bulletin Number: 06004 Bulletin Date: MAR 2006 Vehicle: 2004 Infiniti G35 Summary:MALFUNCTION INDICATOR LAMP WITH DIAGNOSTIC TROUBLE CODE U1000 OR U1010 STORED IN ENGINE CONTROL UNIT. 2002 - 2006 INFINITI VEHICLES WITH CAN COMMUNICATION. ( NHTSA ITEM NUMBER - 10019293 )
Component Description:8. POWER TRAIN:AXLE ASSEMBLY Bulletin Number: 05002 Bulletin Date: NOV 2005 Vehicle: 2004 Infiniti G35 Summary:CLICKING NOISE FROM REAR AXLES. ( NHTSA ITEM NUMBER - 10017773 )
Component Description:9. SERVICE BRAKES, AIR:ANTILOCK:WHEEL SPEED SENSOR Bulletin Number: 03056A Bulletin Date: NOV 2005 Vehicle: 2004 Infiniti G35 Summary:ESSENTIAL TOOL J-45741-INF ABS ACTIVE WHEEL SENSOR CHECKER. ( NHTSA ITEM NUMBER - 10006124 )
Component Description:10. ENGINE AND ENGINE COOLING Bulletin Number: 04018 Bulletin Date: SEP 2005 Vehicle: 2004 Infiniti G35 Summary:ENGINE WILL NOT START WHEN USING A NEW IGNITION KEY. IVIS / NATS SYSTEM DESCRIPTION / KEY REGISTRATION. ( NHTSA ITEM NUMBER - 10017402 )
Component Description:11. POWER TRAIN:AXLE ASSEMBLY Bulletin Number: 05002 Bulletin Date: JUL 2005 Vehicle: 2004 Infiniti G35 Summary:CLICKING NOISE IS COMING FROM THE LEFT AND/OR RIGHT REAR AXLE WHEN ACCELERATING FROM A STOP. ( NHTSA ITEM NUMBER - 10016567 )
Component Description:12. SEATS Bulletin Number: 02080 Bulletin Date: JUL 2005 Vehicle: 2004 Infiniti G35 Summary:DRIVER'S SEAT NOISE AND/OR ROCKS BACK AND FORTH. ( NHTSA ITEM NUMBER - 10016401 )
Component Description:13. STRUCTURE:BODY Bulletin Number: 05034 Bulletin Date: JUN 2005 Vehicle: 2004 Infiniti G35 Summary:NOISE FROM REAR DOOR WITH WINDOW ALL THE WAY UP. ( NHTSA ITEM NUMBER - 10015415 )
Component Description:14. ELECTRICAL SYSTEM:WIRING Bulletin Number: 04020 Bulletin Date: MAR 2005 Vehicle: 2004 Infiniti G35 Summary:TRAILER LIGHT WIRING. TO INCLUDE INFINITI 2006 M35/M45. ( NHTSA ITEM NUMBER - 10012880 )
Component Description:15. ENGINE AND ENGINE COOLING:ENGINE Bulletin Number: 04048 Bulletin Date: OCT 2004 Vehicle: 2004 Infiniti G35 Summary:ENGINE WILL NOT CRANK WITH OUTSIDE TEMPERATURE BELOW 10 F. ( NHTSA ITEM NUMBER - 10010108 )
Component Description:16. VISIBILITY:REARVIEW MIRRORS/DEVICES Bulletin Number: 04046 Bulletin Date: SEP 2004 Vehicle: 2004 Infiniti G35 Summary:RATTLE NOISE FROM REAR VIEW MIRROR HARNESS COVER. ( NHTSA ITEM NUMBER - 10009749 )
Component Description:17. STEERING Bulletin Number: 03028A Bulletin Date: SEP 2004 Vehicle: 2004 Infiniti G35 Summary:STEERING DRIFT TO THE RIGHT. ( NHTSA ITEM NUMBER - 10005686 )
Component Description:18. EQUIPMENT:ELECTRICAL:NAVIGATIONAL SYSTEM(GLOBAL POSITIONING SYSTEM) Bulletin Number: 04042 Bulletin Date: AUG 2004 Vehicle: 2004 Infiniti G35 Summary:NAVIGATION SYSTEM IS INOPERATIVE AND THE DISPLAY SHOWS DISC ERROR OR DVD-ROM VERSION IS NOT CORRECT. ( NHTSA ITEM NUMBER - 10009182 )
Component Description:19. STRUCTURE:BODY Bulletin Number: 04035 Bulletin Date: AUG 2004 Vehicle: 2004 Infiniti G35 Summary:RATTLE NOISE FROM REAR SIDE WINDOW FINISHER. ( NHTSA ITEM NUMBER - 10009175 )
Component Description:20. VISIBILITY:POWER WINDOW DEVICES AND CONTROLS Bulletin Number: 04033 Bulletin Date: JUL 2004 Vehicle: 2004 Infiniti G35 Summary:WINDOW REGULATOR MOTOR RESET PROCEDURE. ( NHTSA ITEM NUMBER - 10009364 )
Component Description:21. ENGINE AND ENGINE COOLING:EXHAUST SYSTEM:EMISSION CONTROL Bulletin Number: 04030 Bulletin Date: JUN 2004 Vehicle: 2004 Infiniti G35 Summary:ESSENTIAL TOOL - J-44626 AIR FUEL SENSOR SOCKET. 2005 ALL INFINITI VEHICLES INCLUDED. ( NHTSA ITEM NUMBER - 10008716 )
Component Description:22. ELECTRICAL SYSTEM Bulletin Number: 04023 Bulletin Date: MAY 2004 Vehicle: 2004 Infiniti G35 Summary:MALFUNCTION INDICATOR LAMP ON WITH DIAGNOSTIC TROUBLE CODE P1031, P1051, P1148, P1168 A/F SENSOR HEATER / CLOSED LOOP. ( NHTSA ITEM NUMBER - 10007680 )
Component Description:23. VISIBILITY:SUN ROOF ASSEMBLY Bulletin Number: 04024 Bulletin Date: MAY 2004 Vehicle: 2004 Infiniti G35 Summary:SUNROOF LID SQUEAK/CREAK NOISE. ( NHTSA ITEM NUMBER - 10007679 )
Component Description:24. INTERIOR LIGHTING Bulletin Number: 04019 Bulletin Date: APR 2004 Vehicle: 2004 Infiniti G35 Summary:VANITY MIRROR MIRROR BULB REPLACEMENT. ( NHTSA ITEM NUMBER - 10007728 )
Component Description:25. ELECTRICAL SYSTEM:WIRING Bulletin Number: 04020 Bulletin Date: APR 2004 Vehicle: 2004 Infiniti G35 Summary:APPROPRIATE HOOKUP POINTS FOR CONNECTING A TRAILER LIGHTS WIRING HARNESS TO THE VEHICLE. ( NHTSA ITEM NUMBER - 10007727 )
Component Description:26. EQUIPMENT Bulletin Number: 04001 Bulletin Date: JAN 2004 Vehicle: 2004 Infiniti G35 Summary:REMOTE KEYLESS ENTRY REPLACEMENT PARTS. ( NHTSA ITEM NUMBER - 10005194 )
Component Description:27. SERVICE BRAKES, HYDRAULIC Bulletin Number: 03069A Bulletin Date: JAN 2004 Vehicle: 2004 Infiniti G35 Summary:REDUCTION OF FRONT BRAKE NOISE WHEN BRAKING IN REVERSE. THIS BULLETIN REPLACES ITB03-069. ( NHTSA ITEM NUMBER - 10005216 )
Component Description:28. STRUCTURE:BODY:DOOR Bulletin Number: 03071 Bulletin Date: DEC 2003 Vehicle: 2004 Infiniti G35 Summary:RATTLE OR CREAK NOISE FROM TOP OF DOOR WINDOW FRAME. ( NHTSA ITEM NUMBER - 10005263 )
Component Description:29. INTERIOR LIGHTING Bulletin Number: 03065 Bulletin Date: NOV 2003 Vehicle: 2004 Infiniti G35 Summary:CLOCK BULB REPLACEMENT. VARIOUS MODELS INCLUDING 2004 I35. ( NHTSA ITEM NUMBER - 10004598 )
Component Description:30. TIRES:PRESSURE MONITORING AND REGULATING SYSTEMS Bulletin Number: 02063B Bulletin Date: NOV 2003 Vehicle: 2004 Infiniti G35 Summary:TIRE PRESSURE MONITOR SYSTEM (TPMS) WARNING LIGHT FLASHES OR STAYS ON. ( NHTSA ITEM NUMBER - 10005225 )
Component Description:31. TIRES:PRESSURE MONITORING AND REGULATING SYSTEMS Bulletin Number: 02063A Bulletin Date: NOV 2003 Vehicle: 2004 Infiniti G35 Summary:TIRE PRESSURE MONITOR SYSTEM (TPMS) WARNING LIGHT FLASHES OR STAYS ON. VARIOUS MODELS INCLUDING 2004 M45. ( NHTSA ITEM NUMBER - 10004597 )
Component Description:32. VISIBILITY:SUN ROOF ASSEMBLY Bulletin Number: 03060 Bulletin Date: OCT 2003 Vehicle: 2004 Infiniti G35 Summary:SUNROOF INOPERATIVE. 2004 FX35/FX45 INCLUDED. ( NHTSA ITEM NUMBER - 10003951 )
Component Description:33. STEERING Bulletin Number: 03028 Bulletin Date: APR 2003 Vehicle: 2004 Infiniti G35 Summary:STEERING DRIFT TO THE RIGHT. ( NHTSA ITEM NUMBER - 10001676 )
