2004 G35x starting problem
tironci01
Car: 2004 Infiniti G35x
Please someone help my i got a 2004 g35x with 53k my battery was dead i recently change it and just put a new one rite after i change it my car starts great but as soon as the rpm goes down the car shuts off i have to put some gas to keep it on. some one told me because u changed the battery the memory of the car got erased any sugsestions
Daniel G
Car: '05 Infiniti G35
Doesn't sound battery related.
DG
PapaSmurf2k3
Site Admin
Does it stall every time the RPM drops? Or is it just when it's cold, etc?
I'll move this to the online mechanic section.
Q451990
Sure doesn't sound like my experiences after a battery change. Have you tried disconnecting the battery for a while and then reconnecting it - just in case you had a "glitch" of some sort?
If that doesn't work, I would have someone check for ECU codes...
Heath
SteveTheTech
Car: 15 Nissan Sentra SR
12 Infiniti G37x Coupe
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
Hi there and Welcome
If I were to take a shot in the dark with no other info than what is listed in the OP. I would say your throttle motor might going or gone. It is fairly common on the early Gs.
Your best bet would be to take it to the dealer. They can see if the error is one of the base parameters or an internal failure in the throttle motor.
It could also be a fault in the Mass Airflow sensor (would be evaluated in the base parameter setting).
