elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Mon Apr 21, 2014 9:43 am
Welcome to NICO.
IMO the oil consumption debate is way over-played. Back in the day, it was considered NORMAL for most German cars to consume 1 quart of oil every 3k miles. My Q45 with 230k miles consumes about that much oil despite having in-spec compression both cold and hot My point is, every couple times you fill up with gas just check the oil level and keep a spare quart in the car with you if you need to top off... Way cheaper and easier than worrying about an engine overhaul. No real long term damage will occur.
The G35 is a fantastic and overall reliable car. People's definition of reliable tends to vary, and overall this car should be a lot cheaper than any German car, and will have fewer problems than most American cars. Parts can be a little more expensive than American cars, but tend to be a lot better made and fail less often.
