Jim2004G35 »
https://forums.nicoclub.com/jim2004g35-u151497.html
Thu Mar 25, 2010 2:41 pm
I am often hearing a loud noise that sounds like someone hitting the bottom of car with a metal hammer when hitting small bump while braking. I sometimes hear the loud bang when going over bumps at slow speed. I think it only occurs when it is the right front wheel hitting bump. I read one post for front suspension noise that talked about a compression rod, but the parts description for front suspension does not have a part by that name. Car was just serviced by Infinity dealer and passed their 27 point inspection. The first couple times I heard noise I thought I had hit a big pothole. But I have heard numerous times when I know there was no pot hole. Have only 33,180 miles on car. At 33,081 miles I had rear sway bar links replaced that solved a creaking noise when going over bumps at slow speed. At 32,538 miles dealer replaced transmission under warranty for synchronizer noise and hard shifting into 2nd gear.
