atpase1 »
https://forums.nicoclub.com/atpase1-u144978.html
Fri Oct 09, 2009 5:28 pm
Well I fixed the problem. From others, it appeared to be 1 of 3 things, either a fuse, the trunk actuator, or the wiring loom at the trunk hinge. It wasn't a fuse problem so I was going to check the power to the actuator. Out of curiosity I pulled the wiring loom out and was surprised to see a single green wire completely severed. This has never been tampered with by anyone, and the loom itself looked brand new. I was quite surprised. I clamped the severed wire with a connector and then flipped the switch....perfect!!! Works just fine. I'm still just baffled that opening and closing the trunk lid over time can severe a wire like this.
