Q451990 »
https://forums.nicoclub.com/q451990-u142.html
Wed Jul 12, 2023 3:30 pm
The service manual doesn't say much about the fan clutch other than to check for wobble, leakage, or bent fins. There are a ton of YouTube videos about this, but as with all things YouTube, opinions vary. Some make a big deal about how long it takes for the fan to stop spinning after turning the car off. Some talk about the "rolled up magazine test."
So how do you guys test a fan clutch? In my truck, it seems like it's always doing the same thing. Right after startup, you can't stop the fan with a rolled up magazine. Same after it's been running for a while. Feels the same cold, or after a long drive with the truck off. The fan never roars after the truck heats up like the one on my Q45 does.
As best I can tell the cooling system is fine. I spent some time with an OBDII scanner hooked up to it today, and the temperature stayed under 180F on a 10 or 15 minute drive in the hot sun on a 90 degree day. I let it idle for 10 minutes, and it still hovered just a little over 180F. I think 185F was as high as I saw.
I have a slight bit of play in the clutch side to side, maybe a mm or two.
Any thoughts?
