Scandinavian Flick »
https://forums.nicoclub.com/scandinavian-flick-u100311.html
Sat Aug 02, 2008 3:32 pm
p1121 means the that the throttle positioning sensor doesnt match the mass air flow sensor, so your car is getting confused as to how much air is actually going into the car versus how much it thinks is going into the car, so it has no idea how much fuel to add,
as for cleaning the throttle body, it would have to have been pretty nasty to restrict the air flow that bad,
first check your air filter make sure its clean,
second you may need to have your TPS sensor checked/replaced to make sure its acting right, also make sure that the wire that runs through the center of the MAF is not damaged, and thats about all i got on that, good luck
