2004 - 4 cylinder X-Terra AC problem.
demilys
Car: 2004 x-terra
X-terra leaking freon, but mechanic cannot find leak. Has tested it with two different leak detectors. Once it has had a shot of freon, blowing hot two days later. Compressor has been replaced. Any suggestions?
CPS
Use AC dye on the next recharge and you should see where it's leaking from. My money is on the high side AC hose.
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
If it's leaking thast fast it should be rather easy to spot with dye. I am not going to bet where it's leaking from. If the compressor didn't fix the problem then you should put your old one back on.
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
I had a rubber hose rubbing on the high side hard line and it actually rubbed a pin hole in the aluminum line on my 4 banger some time ago.
demilys
Car: 2004 x-terra
Thank you for all your help. My mechanic used the dye this time and found a bolt that would not tighten. Will have more info when I pick up my truck today.
