2004 350Z rodster top issuses
Nissan 350z / Nissan 370z general community discussion forum
myfairlady33
Car: 2004 350Z Roadster
It's time to get the Z ready for spring.
Last year I started having problems with the top.
Putting the top down this is what happens:
Push the button and the back latch releases but the top doesn't move.
i can pull the top up slowly from the back to the upright position then
the deck lid will open and the front will start to come up and goes back 75% of the way and I have to help it the rest of the way until it's almost in then the motor takes over and finishes the proceedure.I have lube everything I could findwith white lithium grease.Has anyone else had this problem? if so what is the fix?Are the motors going bad or do the elastic pieces need replced?
Happy motoring
Warm weather is on the way.
Thanks
PapaSmurf2k3
Site Admin
I've never even looked at a Z roadster's roof mechanism, but this would probably be a pretty good place to start:
http://www.nicoclub.com/FSM/350Z/roadster/2004/rf.pdf
Return to “350z / 370z Discussion”
