2004 350Z MANUAL - LOW POWER / P0011 AND P0022 / OIL PRESSURE -- NEED HELP
Nissan 350z / Nissan 370z technical discussion forum: Maintenance, performance, installations, modifications, how-to's and troubleshooting.
rgmolero
Car: 2004 Nissan 350Z Enthusiast
Good afternoon everyone, I hope you are well.
I have a 2004 nissan 350z enthusiast MANUAL, and I have the following problems.
- The car has no power (it costs a lot to raise the RPM), almost impossible to drive.
- Apparently when it is cold it has a good idle / oil pressure, when warm it starts to shake and goes down to 600rpm and turns on the oil pressure light.
- I reset the codes and after a while on they reappear.
p0011 and p0021.
I have tried the following:
- Change all timing chains and their tensioners.
- Change VVTs.
- Change the oil and its filter.
- Change the oil gasket.
- Change the battery.
- Change the injectors.
I'm really asking for your help, I don't know what to do anymore.
VIDEO OF THE PROBLEM
https://youtu.be/hgMpVvkpFOE
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
:welcome:
Unless I missed it, it looks like the only thing you haven't addressed is the code P0021 for the camshaft position sensor. This is above my pay grade, but I suspect it may fix your problem. Anyway I did find a DIY on YouTube that might help.
rgmolero
Rogue One wrote:
Wed Sep 09, 2020 4:45 pm
:welcome:
Hey thanks for your answer, already replaced.
Return to “350z / 370z Technical”
