I'll start putting on posts about various fixes I have found and common issues, including:
- power sunroof leaks (easy fix to Nissan going cheap - takes a little work)
- roof glass leaks (EASY fix)
- rear leaks (not too bad)
- suspension (easy fix - replace everything)
- brakes (easy fix - lose the standard OEM (or generic) rotors, pads, and calipers ...and use drilled/slotted PowerStops...no, I'm not kidding)
- engine (timing chain - OK, this one will cost you a bit to fix Nissan's screw-up)
- the junk CD player (easy fix to Nissan's screw up)
- the poorly designed gauge ribbon cable assembly problem (VERY easy fix to another design screw-up)
I'll be completely done in about two weeks - more to follow. I think I've seen about anything you can run into.
