This kit will work on 2004 - 2006 G35 Sedan and 2004 - 2007 G35 Coupe that are pre-wired for SAT radio, which those year ranges should be.
As you can see in the first picture, the 2004-2005 G35 Sedan SAT harness is behind the panel against the back seat mid passenger side down low. On the 2006 G35 sedan it is located under the rear package tray on the passenger side.
For the G35 Coupe it should be located in the trunk, on the driver side behind fender panel near spare tire well.
If you have SAT radio installed and wish to continue to use that option, you will need an additional harness, so please specify.
PM me for prices!!!
