2003Z »
https://forums.nicoclub.com/2003z-u288768.html
Sun Mar 24, 2019 9:12 pm
I was driving my 2003 350Z in some very heavy rain a month ago. A few hours later I was driving and the car suddenly lurched and lost complete power, not even the interior light would light. I disconnected the negative battery cable for 10 mins and it restarted fine. Got a block down the road and it completely died again. Repeated disconnecting the battery for 20 mins and it drove normal again back to work. After work, I jumped the battery for ten mins to charge it up and got 30 mins before it completely died again.
Tried the car last weekend after a few weeks of drying out and it started fine but suddenly died after 22 mins of idling in the driveway on a warm day. The battery voltage is about 12.6 and alternator at 14.5. Battery, alternator and new starter all previously tested good at O'reillys.
Seems like either an intermittent loss of battery ground, intermittent bad alternator or flakey IPDM. Its original alternator with 215K miles on it and a two or three year old battery. The car always seems to restart if either the battery is given a break to come back up after heavy loads without the alternator charging it, or perhaps whatever fault tells all the BCM/ECM/IPDM to shutdown everything, goes away after the battery is disconnected and the fault clears then allows the car to run for a while. There are no OBD codes or engine light on the car.
A year and a half ago a shaddy dealer told me the IPDM was bad but I've driven it for 15K without any issues up until now. Only strange fault I have is that the parking/clearance lights occasionally come on by themselves after the keys are out and light switch off. I've pulled the fuse and suspect a bad tail light relay stuck on. Cause I pull the fuse often, I usually have the cover off the IPDM which could account for water getting in it that one day except it still dies even a month later. Other anomaly was related to a low battery in the key fob that similarly cause the car to occasionally completely have no power after locking it with the fob.
So I'm leaning towards replacing the IPDM with a used unit. Question I have is there only one model number for a 2003 Z with manual transmission? The car is a Track model with VDC and tire pressure monitoring - CAN type 7. The dealer just goes by VIN number and can't tell me if there's different IPDMs depending on these options. Anywhere to get an IPDM other than ebay?
Thanks for your help
