2003 y34 center cluster bulbs
paranoidjack
Car: 2012 Infiniti M56 S
2003 Infiniti M45
2001 Infiniti QX4
2000 Infiniti Q45
1998 Nissan Pathfinder
1996 Infiniti J30
Hey folks,
I have a bulb or two out in the center cluster, for the "info" and whatever is to the right (pcat or something?), and I ordered some bulbs to replace them. Turns out eBay was wrong in matching up, or perhaps I misunderstood them to be center cluster when in fact they are gauge lights..
I read can get the IOS ones for clock for $11 each, so fine NP, but for the cluster lights, does anyone know which they are?
paranoidjack
2003 Infiniti M45
2001 Infiniti QX4
2000 Infiniti Q45
1996 Infiniti J30
PS, I did read this reply
MaxBolus wrote:Well, sorry for the loooong delay, but here's a followup (a year late).
I had ordered the T-1 standard LEDs from superbrightleds and did nothing with them for almost a year. Finally my clock bulbs went as well, and I realized how much I use that clock, so decided it was time to replace the bulbs.
(The clock takes larger bulbs, which I eventually ordered from the dealer- about 11 bucks per bulb, 2 needed.)
I also installed the LEDs I had bought, but was disappointed that they were much dimmer, with uneven lighting on the center console.
So I figured no biggie, since all 8 LEDs only cost about $13. I went back and ordered the high-output LEDs to give them a try.
The result was about the same- relatively dim and uneven :frown:
from the following thread:
post6417669.html?hilit=y34%20bulb#p6417669
But as you see, there is no answer for the center cluster bulbs. Max, if you see this, did you find an answer?
This is GOT TO BE A SHARED BULB with other nissan cars. I am about to just order some for a 03 Q45...they've got to be the same!!!
