looking forward to some good reads and info around here to go with my recent purchase a 2003 sand xe 4x4 V6 that i've yet to have much fun with. Not to worry, this truck has found a good home for that
I actually had the truck sitting for a couple of months since purchasing it and when i went to use it for a weekend i notice on my scan gauge that my battery was running everything and assumed that the alternator was probably to blame. Or so i assume with the little practical trouble shooting abilities that I claim to own.
I've since replace the battery as it was holding very little charge and was the original part. So that should be part of the problem sorted then...Now comes the inquiry that i am looking for some advice on.
I'm trying to remove the alternator to have it bench tested and can't seem to find a way to get the larger (closer to the rear) of the plugs removed. I can't feel anything other than a boot which i can peel upward and then feel heavy wire and nut junction. There doesn't feel like a clamp or something plastic to unlock on this plug. It is very fixed and i've trying prying it off blindly with a hooked screwdriver but just chipped a small bit of the ceramic housing off.
This is scratching a hole in my head and i spent a good couple of hours of finger torture trying to get it off without removing anything other then the belt fron the alternator itself.
The location is ideal and i could concievable remove it like this if i could remove that darn plug. Do I need to remove the front end or something extremely involved as that?
I can't wait to hear some advice and really appreciate any thoughts or ideas that come from my frustration. Apparently my visualization for this success will need a cheat or two to complete this task.
Thanks for your help
