I have a 2003 SL which I am hoping to sell, after I finish some basic repairs/upgrades.
1. I've installed a Pioneer NEX-4000 radio in the car and am trying to hookup the backup camera. The camera will display on the radio if I select it manually from the settings, which leads me to believe the green/white wire I have posi-tapped into isn't the actual reverse wire. Would someone mind helping me figure out where the wire actually is?
This is what I have tapped:
2. Does anyone have a suggestion for how to replace the rear cup holder and where I might find that part? For some reason, it will not come out unless it is gently pried with a screwdriver. I haven't had the car long, and this has never worked, so I am unsure as to whether or not it is a push spring, or if there is some other way that it is to be used, so...thoughts?
Any help would be greatly appreciated!
Thanks,
Andrew
