I bought my pathfinder in May of 2011, and I'm still in the process of learning how to do general maintenance and simple fix-its.
So far all I've done to my pathy is a couple of oil changes, a K&N FIPK, cabin filter replacement, and some cleaning here and there (LOTS of washes
Anyways, my latest adventure is changing the transmission fluid. I just rolled up on 90,000 miles and decided to give it a try.
I've noticed slight slipping in situations such as rolling up to a stop light. Let's say I'm coasting into a red, and it turns green. When I get back on the gas, it slips slightly until it catches the gear. I've heard good things about Lucas "Stop Slip" fluid, so in this change I'm planning to add a bottle of that just to see if my slips can somehow be remedied.
I found a FANTASTIC reference on this forum ( http://www.nicoclub.com/archives/how-to ... r-qx4.html ) but ran into a slight problem on my part-time 4x4 SE model pathfinder. It mentions on there the hard pipes that run along the front side of the pan and cover up 4 (?) bolts underneath it needed to crack the pan and change the filter & gasket. I snapped some pictures, or tried to rather, of my transmission pan and the pipes running towards the front of it. Last weekend I was absolutely stumped as to what the best tool would be to get in there and take off those 4 bolts.
...So does anybody have any tricks up their sleeves to help me out here? What's the best method? Tool?
I'll definitely keep a close eye on these forums in the next few days, thanks in advance for any help.
~PD
