That will get it sold without the wobble but given the 3mo warranty indicated, that set may not last more than a year or two before they need to be replaced again.rckeeps2 wrote: ↑Mon Aug 08, 2022 7:28 pmso something like this would get me right?
https://www.carparts.com/details/Infini ... TID=zlaaff
Inspection can take two forms. One, is to get under there with a flashlight and examine the bushings. If you see any cracks in the rubber then they're compromised. The other is to firmly get ahold of each arm and twist. A good method is to grab each arm at about the middle with a pair of vise grips and try to twist them. If you can move them more than about a degree or two the bushings are no good. If you had the arms replaced a couple of years ago that is a really shortened life. Some people have had this happen when they installed and torqued to spec but failed to do so with the car on the ground.rckeeps2 wrote: ↑Tue Aug 09, 2022 7:10 amGreat, I might take the gamble. I had the lower arms replaced 2 or 3 years ago, should i start with just the uppers, or just do both? The wobble is pretty nasty.
Is there any way to check the condition of them before i take them off? I was under there and grabbed them and shook them, and they seemed solid, but now that I know they're the culprit, i could probably check more thoroughly
I have been meaning to replace mine, just havent gotten around to itrckeeps2 wrote: ↑Sun Aug 28, 2022 6:12 pmFixed my death wobble!! Bought some new upper and lower control rear arms (the ones linked above), and tossed them in and maaannnn does it drive straight now1 Hasnt rode this smooth in years. Fought a few bolts, but an angle grinder took care of them, and replaced it with some new hardware. Thank you all so much for your replies!!
Thanks so much for the info. I want to have the replacement hardware on hand before i start the project so i dont have to run around last minute. I do have another question or 2...rckeeps wrote: ↑Tue Aug 30, 2022 10:52 amFrom my local ace hardware. They were all M14, 1.5 pitch, around 100mm in length. I cut the ends to size for a couple of them so I could get my sockets on the nuts, which is part of the reason I needed new hardware in the first place, since the factory bolts were a little too long for my sockets too and they stripped a little.
Definitely want class 10.9 bolts.
Yeah, I can say I’m one of those people, haha. I made that mistake of torquing while the vehicle was off the ground and axle hanging. I replaced my arms about 6 years ago on my 1997 Pathfinder with some cheap 1Aauto links that have surprisingly made it this far. I paid about $130 for all 4. Now it’s showing signs of needing replacement. I don’t get a bad sway on the highway, even at speeds over 70 mph but it has gotten rockier so I know the time is coming. Everything else suspension wise is up to par and replaced with quality parts. The links were the only things I went cheap on at the time.MisterH wrote: ↑Tue Aug 09, 2022 9:53 amInspection can take two forms. One, is to get under there with a flashlight and examine the bushings. If you see any cracks in the rubber then they're compromised. The other is to firmly get ahold of each arm and twist. A good method is to grab each arm at about the middle with a pair of vise grips and try to twist them. If you can move them more than about a degree or two the bushings are no good. If you had the arms replaced a couple of years ago that is a really shortened life. Some people have had this happen when they installed and torqued to spec but failed to do so with the car on the ground.rckeeps2 wrote: ↑Tue Aug 09, 2022 7:10 amGreat, I might take the gamble. I had the lower arms replaced 2 or 3 years ago, should i start with just the uppers, or just do both? The wobble is pretty nasty.
Nissan recommends replacing them, as do other automotive makers and every other model, yet most DIY mechanics don't bother if the bolts and nuts look to be in good shape.
Yes, it is definitely not a fun experience when those links are really shot.
The noise has eased up over the weeks since installing them. But yes, I did drop the weight of the vehicle onto the axle before torquing the bolts down.Buzzman wrote: ↑Tue Dec 20, 2022 5:46 pmMake sure you have the vehicle back on the ground, with full weight on the suspension before torquing everything down.
Tightening everything up while it's still in the air, and the axle hanging down, can cause stress later on. That may contribute to the noise in the driveline.
They ended up having to get them from another service center, but it only took one day.
