2003 QX4 - Perpetual OBDII "Gas Cap" Readings
tjjarc
Car: 2003 Infiniti QX4
I am the proud owner of a 2003 QX4 and been having an issue lately. The Service Engine Soon light tripped about a month ago and the OBDII reading suggested a "loose gas cap (ie, small pressure loss). After reseating the cap and clearing the code, the light stayed off for a week and then reappeared. I got it checked and received the same error code. Once again, I cleaned the gas cap and confirmed a tight connection and reset the SES light. A few weeks later, the light is on again.
Other than the light, the car is running great.
Could this possibly be a sensor issue? Should I try another gas cap? Anybody have any ideas?
Thanks.
Q45tech
During an emission test the cap is removed and is placed on a machine to verify it's performance.
driftingmy240sx
Car: 1996 Nissan 240sx rb25det
i would bet on a cracked evap canister or poorly seating vent control valve. that is if the code is an "evap small leak" code.
MaximA32
If it's a gross evap leak, I would check to make sure that there isn't rust built up around the filler neck.
Alt.240.130
Car: 2006 Altima 2.5 Special Edition 1996 240sx SE
You dont fill it up while the car is running do you?
