2003 Q45 Charging System
arwe
Car: 2003 Q45
Hi, I drive a 2003 Q45 and it appears that the charging system is not working. I can start the car with a jump but the battery does not charge with driving.
Assuming that the battery itself is OK and can hold a charge (which I have yet to prove), what simple steps can I take to find the problem before I take it to a shop? I'm a bit mechanically able but don't have the diagnostic tools or know how to do a thorough charging system test.
Could it just be a fuse? The problem started soon after I partially dismantled the center console and central dash to get the CD changer out. Maybe I blew a fuse in the process.
Any recommendations appreciated.
qship96
Car: 1996 Infiniti Q45
You want us to guess??? Only way to determine problem is to TEST components like battery/alternator/key off power consumption.....without doing that any answer you get here is just a guess.........my first GUESS would be that it is a aged failing battery.
Q451990
If you have a volt meter, a quick check is to check the battery voltage with the car off, and then at idle. Off should be about 12V, idle should be around 14.4V.
Heath
arwe
Car: 2003 Q45
Q451990, thanks for your helpful reply. :)
I do have a voltmeter somewhere.
If the voltage does not rise when the engine is running, does this indicate that the battery is not being charged?
Q451990
Yes.
This isn't the end-all, be-all test - but it's a good start. If you see no rise, you know the alternator is not charging. If you see a voltage rise, then you need to think in terms of load testing the alternator to make sure it's holding up under a load. If your battery shows 12.xx VDC with everything turned off, and then drops way down during starting, then you can be sure your battery is shot - assuming it was properly charged in the first place.
Good luck!
Heath
Q45tech
The 2 decimal places after the 12.xx are extremely important as those with a temperature chart show the EXACT charge condition of the battery [unloaded].
http://www.buchanan1.net/lead_acid.shtml
12.00 volts at 77F is only 50% charged whereas 12.63 is 100%
