nickelghandi »
https://forums.nicoclub.com/nickelghandi-u215217.html
Wed Apr 25, 2018 7:39 am
You can remove that cowl pretty easily and see for yourself. Also check toward the front of the driver and passenger side doors. There is a pocket type thing in there that is supposed to drain to the ground, but frequently gets clogged with leaves and other debris. The cowl drains may actually lead to that pocket thing. I can post a pic later when I am home. Mine probably needs cleaning so you might even get to see the debris lol
