Buzzman »
https://forums.nicoclub.com/buzzman-u55955.html
Fri Jan 30, 2009 5:58 pm
Ok, first of all, your engine doesn't have a distributor, so don't listen to your tow truck driver.Secondly, with the engine running, the battery should be reading around 14-14.5 volts, not 12.You may want to start with having your alternator circuit checked, and go from there.My son's Maxima had similar problems, and after a so-called tech said he needed a new battery, the problem returned. It was actually the alternator. He wasted his money on a new battery.Good luck and keep us informed.
