2003 pathfinder no heat!!
restojeff
Car: 2003 pathfinder
someone "flushed" the system and now we have noheat after about a 4 mile drive, have done every kind of bleeding procedure, replaced both thermostats w/o any change. HELP PLEASE!!!
nissandoms47
Car: 2002 Nissan Pathfinder SEV6-Custom 7" lift-33-1250R15 BFG KM2- a bunch of other s*** i cant think of
i had this same prob. you need to let the engine cool off and then you need to filll the radiator up and keep repeating those steps until your system is full. on the vq pathys there is no easy bleeder screw like the older vg engines.
Chuck Tribolet
Car: '01 Nissan Pathfinder
'87 Chevy Corvette
'01 Toyota Camry daily driver
'98 Boston Whaler Montauk
On my stickshift '01 PF, there's a rubber cap on a metal line, roughly centered,just forward of the firewall, just below the hood line. You pull the cap off and it vents air out of the coolingsystem. Keep adding coolant mixture until the radiator is full, then cap thevent line.
The factory service manual says "vent plugs" (plural) but the picture only showsthis one, and I've only ever been able to find the one. The Haynes manualshows another on top of a cross tube at the front of the engine, but minedoesn't have that vent.
Modified by Chuck Tribolet at 9:56 AM 1/1/2009
screwinitupagain
Car: 1997 Nissan Pathfinder SE
Hell I don't know hwy you are complaining it was high 60's here today... I rolled around with my windows down
nissandoms47
so thats what that rubber cap on that metal line is. i always thought it was something to do with the evap system.
