Hawairish wrote:I'm certain you've got the automatic climate system
I do indeed have the automatic climate system.
Hawairish wrote:1. The door positions are out of sync
If this were the case, would the motor continue to 'spin' and try repositioning the door? Would there be a fix that doesn't include dismantling the entire dash?
Hawairish wrote:That clicking noise may very well be the blend door motors spinning against a plastic gear tooth...perhaps a tooth has chipped, or the some plastic nearby has cracked allowing the teeth to slip (click click click).
This hadn't occurred to me. I like the train of thought, however, I assume that once the blend door is in position, the motor stops trying to turn it, and therefore the noise would stop once the door was in position no?
Yes I did look at the Manual before posting, and I plan on trying the diagnostic mode this week. Thanks for the reply!
