I need to have them turned at minimum. They are out of round.yeldogt wrote: ↑Thu May 17, 2018 10:00 amI always use the OE pads (not the value line) think they are around $70 bucks online. Long trouble free life. The Zimmerman rotors are fine as replacement when that's needed.
Have had three LE pathfinders and never have any issue with the front brakes .. unlike most. The front rotors are expensive and a pain to replace ... the rotors last through two sets of OE pads.
Agreed on not turning rotors anymore. But I think it's the change in pad formulation more than anything. Back in the good/bad old days of Asbestos pads, they were much more forgiving in a lot of ways. Lungs of course not being among them, but they weren't bad for stopping and noise, nor hard on rotors. But todays pads are not rotor friendly. With the possible exception of ceramics but they don't seem ideal for a truck type of vehicle. I too am in the market for a good, not too expensive fade resistant pad.
Talking about these, correct?yeldogt wrote: ↑Sat May 26, 2018 4:41 amMike W -- I own a company with a fleet of cars. Have for almost 30 years -- so I have experience with some brands ... and I read the fleet magazines. Brakes are always a discussion with motor heads (as is oil). A given company may have design issues that causes a particular model to act up ... but in general companies don't just order any old pad and rotor combination. It's sort of a general rule if you want problem free -- stick with the OE pads and replace the hardware. Rotors are a question of quality and cost ... Zimmerman makes great rotors ... if they are available and the OE are overly expensive ... We get the Zimmerman. Will also use Brembo/ Akebono as an end of service brand ... I will often replace all rotors/pads/tires on a car I'm going to keep another year and 25k.
Ford at one time had rotor issues on some FWD cars -- if you did not get the updated OE and set the wheel bolts correctly -- you had major warping issues. Nothing else worked .. so only OE. With the Pathfinders -- the Zimmerman/OE pads perform very well. With teh extra cost of switching out the front rotors ..getting the best service life is what I'm after. The OE pads are not expensive .....if you get the OE and set them next to Akebono aftermarket -- you can see they are not the same. And by all account Akebono makes the pads. Using online dealers -- I find I can get good prices. The rear brakes are a pain -- I'm not a fan of drum .. and I really use the OE back there.
