Buzzman »
https://forums.nicoclub.com/buzzman-u55955.html
Thu Jul 26, 2007 4:49 pm
Fueler may be right. We've had many discussions on the K&N filter issue. However, if I read the original post correctly, the truck ran fine until he did the exhaust system. The only way to alter the back pressure is by installing a different system.Now, I would still suggest checking out the MAF sensor like Fueler said.Did you recently clean and re-oil the filter element by the way?I've run my truck with a K&N filter for over two years, and have not had a problem. When I clean and oil it, I leave it out in the open for 24 hours before installing it back in the truck.As for finding vacuum leaks, I have a rather strange way of finding them, but it has worked for me in the past. It's probably a little dangerous, so be careful. Do this in a WELL ventilated location (outdoors):With the engine running, take a plumbers propane torch (like one for soldering water pipes), and open it up a bit, but DON'T light it. move the nozzle around the engine compartment, near hose connections and such. If there is a vacuum leak, it will suck in the propane and change your engine speed. Trust me, when you find one, you'll know it right away. Good luck.
