2003 Pathfinder(Chilkoot) rear hydraulic brake hose/ cant source one
palmdizzo
Car: 2003 Nissan Pathfinder
2003 Nissan Pathfinder, i am having a hard time sourcing a rear hydraulic brake hose for my 2003 Pathfinder. the only ones i can find have one port on the little block end of the hose.the part that i need has 2 ports on the block. bothe rear brake lines screw into the little block
iam trying to attached a photot but it wont let me
any help i would appreciate
cheers
Mike W.
Car: 2003 Infiniti QX4 with a drinking problem. Gone but not forgotten
2002 BMW 525it
2002 BMW 530i/ manual trans
The dark side, 2008 4Runner.. We'll see.
Have you tried one of the online places where you can plug the VIN to get (hopefully) vehicle specific parts?
https://parts.nissanusa.com/nissanparts ... hid=&year=
Never dealt with them, just a guess. Or a dealer.
palmdizzo
i sure have i keep getting the same rsults, i only get the P/N that only hase the one port on the block
MisterH
Car: 1999 Infiniti QX4
RockAuto has it. I'm guessing your pathfinder is RWD as it appears they're the only models that use that hose.
https://www.rockauto.com/en/catalog/nis ... +hose,1792
palmdizzo
well i guess technically it is RWD, i have the "alltime" and 4H and 4L options switch
palmdizzo
this is the one i got, fingers crossed
https://www.rockauto.com/en/moreinfo.ph ... 952&jsn=13
R50JR
Car: 03 pathfinder le
palmdizzo wrote:
Thu Oct 17, 2019 11:31 am
If I am understanding correctly, you are looking for a normal brake hose that has two ports for hard brake lines. If your vehicle has vdc (probably doesn't) it will have two brake hoses, one for each hard brake like. More than likely you got the correct part for a pathfinder without vehicle dynamic control
