2003 Nissan Frontier keeps blowing MAF sensors; Check Engine Light ON
m6ride
Car: 2003 Nissan Frontier KA24DE 2WD automatic
~ ~ 2003 Nissan Frontier keeps blowing MAF sensors; Check Engine Light Keeps Coming ON (disconnected the black bat cable to reset ECU; light OFF, that stopped working too) ~ ~
So, now I'm back to ordering a new MAF to see if that, plus battery cable off for a few hours, to see if that will turn the light off.
Anyone been experiencing this problem ? .... and the solution, please.
Any ideas or suggestions?
THANKS
m6ride
Does anyone have a recommendation on best or excellent diagnostic equipment?
How about this (from ebay listing)
http://www.ebay.com/itm/FIXD-SUPERIOR-A ... 0033.m2042
FIXD SUPERIOR AUTO DIAGNOSTIC ENGINE SCANNER FAULT ERASER HEALTH MONITOR
Popular 1 viewed per hour
Email to friendsShare on Facebook - opens in a new window or tabShare on Twitter - opens in a new window or tabShare on Pinterest - opens in a new window or tab | Add to watch list
Seller information
socalsellersu.s.a (163 )
99.4% Positive feedback
Follow this seller
See other items
Item condition:New
Time left: Time left: 28d 07h 10/7, 1:06PM
Quantity:
1
3 available
Price:US $29.99 Buy It Now
m6ride
Well, yesterday, I disconnected the battery, replaced the MAF sensor with a new one and reconnected the battery about an hour later.
I cranked it up and the check-engine-light went out, just like a NEW truck.
But, it won't last long; I believe the O2 sensors are bad, because this fix is only temporary, as it has been in the past.
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
are you pulling the actual codes or just throwing parts at it?
m6ride
another thing, the rubber hose that connects under the AIR filter assembly (maybe vacuum hose ~8mm diameter ? ); mine broke off - can still connect, but need to replace it.
Does anyone know where to purchase the correct replacement rubber hose ?
Also what is the exact detailed description of this rubber hose ? (ID, OD, etc)
THANKS
m6ride
would someone post photos on how to release the O2 sensors connectors (O2 sensor-to-the-O2 wiring harness; KA24DE 2003 Nissan Frontier.
Better yet, a short video of each on youtube would be great; THANKS
All of these connections seem troubling to me.
m6ride
Well, I changed out both O2 sensors, plus the MAF sensor; disconnected the neg cable on battery ~ 12 hours (CHECK ENG LIGHT OUT), and got 25.3 mpg; the best I ever obtained (cool weather and steady 65 mph.
I'm elated.
Still not sure the timing is set correctly - will get around to that soon.
m6ride
800 miles; check engine light back on; i suspect the catalytic convertor is bad;
does any one know the code for BAD CATS ?
I have a scanner ordered; due any day now.
m6ride
Well, folks, I believe I found the problem.
This guy on Youtube explains how an exhaust leak can cause the P0420 code
https://video.search.yahoo.com/search/v ... tion=click
