alank108 »
https://forums.nicoclub.com/alank108-u123531.html
Fri Jan 02, 2009 9:07 am
I have recently purchased a 2003 Altima 2.5 from a friend of mine, ive had the car since may and its been nothing but problems. As of late it has been dieing at random times, usually at speeds over 40. the car has almost 46000 miles on it, but it only has 6000 miles on the engine. the engine was replaced by a nissan dealership under one of the recalls. i'm pulling the p0335 and the p0725, i was told the engine speed signal code came up because it was triggered by the crankshaft position sensor. now about a month ago i changed the crank sensor and the car drove alright. after i changed the sensor after the first month it died again while i was driving and i pulled the p0335 again. Now i end up in bad situation where my car dies and i end up whereever i can manuver the car. I'm planning on doing a trade in at a dealership but i need to fix this problem first. any ideas or and help at all would be appriciated, if anyone could let me know how to make this problem stop id be happy with keeping the car considering the deal that i got on it.
also i dont know if this relates to the cars other problems but ever time i try to start my car it needs to be done twice, as the first time it turns over and dies immediately and the second time it stays on just fine. i have also read some posts where people have the same problem with there cars dieing while driving but they usually die while stopping or turning at low speeds, mine specifically will die at mid level speeds or higher speeds.
if the problem really is a bad crank sensor again i have no problem changing it...i just dont think its likey. i'm pretty good with cars mostly old school muscle but ive learned my way around my altima so i should be able to do any of your suggestions myself.
I just need to fix these problem schools starting again and i work everyday i need to be able to get around.
