Buzzman »
https://forums.nicoclub.com/buzzman-u55955.html
Sun Nov 06, 2016 7:14 pm
Having a 2006 Altima myself, and having to replace calipers and stuff, I can sympathize.
No point in trying to figure it all out until you have done both sides. Never do just one side.
In my case, being in a salt belt, my caliper pins rusted. When they rust, they expand, and this caused them to seize.
The caliper could not slide, thus the pads could not back off from the rotor, and my wheel/rim got really hot.
That's how I first noticed it: super hot to the touch wheel.
Getting the seized one off the rotor was a real challenge. I couldn't get the pins out.
I removed the caliper assembly instead, and then found I couldn't collapse (push in) the piston. It was seized as well.
I had to replace everything, including the caliper mounting bracket.
I did the other side, and it was almost as bad.
One winter later, the rears were seized. Same process.
Now, in regard to the collapsed brake line: It does happen. I had that problem with an older Ford Escort I had.
The collapsed brake line would not allow the fluid to "reverse", resulting in the pads always pressured against the rotor.
Took a while to figure that one out.
I have not heard of that problem on Altimas.
